Chipsets on board
ASUS
M4A89GTD Pro/USB3 AMD 890GX+SB850 mainboard
Bluetooth 27 Feb 2010
Chipsets
1
AMD 890GX North bridge
AMD SB850 South bridge
Realtek ALC892 audio codec
VIA VT6308 1394 controller
Realtek 8111E GbE Controller
NEC USB 3.0 controller chip
ICS Clock Gen
Turbo EVO chip
Jmicron chip provides 1 IDE channel and 2 SATAII ports
MemOK on board switch. Press and hold if you see the LED
light is on , indicating a ram incompatibility. Press and hold the MemOK!
switch until the DRAM LED starts blinking to begin automatic memory
compatibility tuning for successful boot
Turbo Key II switch allows you to auto tune your CPU to
enhance the system performance. Core Unlocker switch enables you to unlock
the hidden cores of your CPU. It can easily unlock the hidden cores on your
Phenom II X3 710 or 550BE to make it a 4 cores processor.
