Foxconn C51XE2AA-8EKRS2H NV 590 SLI Mainboard Benchmarks 4/8
Benchmarks - 3DMark2005/2006 We paired up a ASUS 7600GT with both board and loaded them with Forceware 84.21. The boards peforms quite well. It isn't difficult to see that both the ASUS and Foxconn performs on par to each other but falls 10points behind the ECS KA3 MVP Extreme. The two other entry level boards by ASRock seems to be a bit weaker in this test. We also tested the option in the BIOS NVIDIA GPU EX Enabled by enabling it. The result is slightly better at 6015.
In 3Dmark06, the results are quite different as we see that the Foxconn seems to be slightly slower than the rest. In fact, it is shocking to see that the difference of the ASUS Board leading by 18 points. The ECS KA3 MVP Extreme is in between the two 590 SLI as they are considered of the same high end chipset. With NVIDIA GPU EX Enabled, the score went up to 3231. Will this give a boost to other benchmarks. Lets press on.
