Sample images of
DVB-T MPEG2 vs H264 broadcast
of |
More Photos of of MPEG2 digital broadcast
The DTV can also receive MPEG2 encoded DVB_T broadcasts in addtion to HD5 (H.264). If you look at the images captured, you would notice that the HD5 appears sharper. Just check out the HD5 and Ch 5 image below and see for yourself.
Although you can't receive Ch U, Suria, Central as they are not broadcasted in Digital Terrestial, you can receive TV mobile using your indoor antenna. For watching other local channels, you would still use the AV in connected to your cable set top box.
