Review of Samsung Omnia Pro B7610  Windows Mobile 6.5 QWERTY phone
OCWorkbench 18 Jan 2010
We first saw the Omnia Pro B7610 at CommunicAsia 2009 held in Singapore last year. Compared to most other QWERTY keyboard based solutions, the Omnia Pro B7610 can be said to have the larger and spacious layout of the keyboard for easy test entry.
Complimenting the keyboard is the 3.5" touchscreen display that has a resolution of 800 x 480 (WVGA) and is of the AMOLED display. It reproduces very good black and colours. Powered by the Windows Mobile 6.5, it's central processor runs at an amazing speed of 800MHz, just 200MHz slower than the SnapDragon variants.
The phone is customised with two user interface, the Work mode or Lifestyle mode. In Work mode, you will be greeted by the standard Windows interface with calendar, mails on the main screen. By pressing the side button, the phone switches to the Lifestyle mode. In Lifestyle mode, Samsung customised the screen with TouchWiz 2.0 and a 3 page customisable web front where you can drop your widgets just like you do on the Samsung JET.
Connectivity-wise, the company hasn't skimped by including everything you could possibly need in a high-end smartphone. These include HSDPA, quad-band GSM, Wi-Fi, Bluetooth and GPS for navigation.
The Omnia Pro B7610 comes with a  5 megapixel camera with autofocus and flash. It delivers pretty decent pictures. It also does video recording at 720x480. As it has a hidden QWERTY keyboard, it makes this phone slightly thicker than the rest at 16.2mm. Other neat features include Divx playback, DLNA enabled for multimedia.
Unboxing of the Samsung Omnia Pro B7610
Specifications
General
Phone type
Slider
Operating system
Microsoft Windows Mobile
Dimensions (H x W x D)
112.6 x 57.8 x 16.2 mm
Expansion slot(s)
microSDHC, microSD
Built-in memory
1000 MB
Connectivity
GSM frequency bands
Quadband
Connectivity options
EDGE, GPRS, HSDPA, Bluetooth, A2DP, WLAN, TV-out
Display and Text Input
Display size
3.5-inch screen
Display resolution
WVGA
Display type
OLED
Touchscreen
Yes
Keypad
QWERTY
Performance
Battery capacity
1500 mAh
Main processor speed
800 MHz
Multimedia
Maximum camera resolution
5 megapixels
Imaging features
Autofocus
Sound features
MP3 playback, WMA playback, FM radio
Discuss >>>
