Pictures of
Samsung Omnia Pro B7610 WM6.5 QWERTY phone
OCWorkbench 18 Jan 2010
Photos of Omnia Pro B7610
Samsung Omnia Pro B7610 from different angles
The front showing with a three button design. The left is for terminating calls.
The right button is power on/off and dial call. The centre button access MY MENU
which shows you a conventional 4 page icons interface to edit shortcuts.and a
task switcher to terminate or switch applications.
The back plate and the 5 megapixel camera.
The side with the volume keys and W&L (toggle between work or life interface)
The right side with camera button and screen lock button
Discuss >>>
