BIOS Screen shot of
ECS H55H-CM Intel H55 Mainboard
Review Bluetooth 3 Jan 2010
BIOS 1
The CMOS set up utility mainpage
There aren't many settings available. Over here you can
see TCM Support and ECS eJIFFY enable/disable function
Over here you can set the allocated memory and HDMI audio
The only overclocking option is the multiplier optoin . As we
use a Core i5-661, it is set to 25x. The maximum is also 25. There are no
options to change the BCLK.
