ECS eJIFFY on
ECS H55H-CM Intel H55 Mainboard
The eJIFFY function must first be enabled in the BIOS. Next, you would have to install the software provided in the CDROM. Once that is done, you will be greeted with this boot up screen. Use the mouse and click on eJIFFY and you will be able to get access to internet applications for instant messaging, web browsing, pictures viewing all without the need to enter the OS.
Inside eJIFFY, you can configure the language and keyboard choice. Many international languages are supported. Below is a screen shot of eJIFFY at work, showing the website http://en.ocworkbench.com
