Dual H.264 video stream
playback on
ECS H55H-CM Intel H55 ClarkDale Mainboard
Video playback In this test, we check out the performance on playing back MPEG4 AVC clips using PowerDVD 9. In a 2nd test, we check out if it is possible to playback two simultaneous streams using both PowerDVD 9 + Windows media player in Win 7 and check out how it affects the CPU utilization levels. Video clip "The Bourne Ultimatum - Trailer" H.264 1080P clip* Single Stream
The average CPU utilization is 10.736% with a min of 2.344% and a max of 29.688% Dual Stream
The average CPU utilization is 11.981% with a min of 2.344% and a max of 33.988% Looks like the processor is able to handle two streams pretty well. A similar configured AMD 785G with Phenom II X3 710 o/c to 3.33GHz managed to do a single stream at 14.67% and dual stream at 16.776% CPU which is higher than the Intel equivalent. * The tests were done on ASRock H55M Pro. As it is based on the same chipset, the results will be identical.
