DiVX Encoding tests benchmark of ECS A890GXM-A AMD 890GX+SB850 mainboard
Bluetooth 1 Mar 2010
Benchmarks - DIVX 7 encoder
In this test, a full HD clip is put to the compression test to Divx Plus HD and Divx Mobile Format. In the chart below, the shorter the time to completion equates better performance.
We can see that the 3 boards all took almost the same amount of time to process the HD film converting it to DIVX plus HD and Divx Mobile format.
