BIOS Screen shot 2 of ASUS P7H55-M Pro mainboard
Bluetooth 3 Jan 2010
BIOS 2
Under AI Tweaker, you can also adjust the memory timing information. In this case, the default timing of 9 9 9 24 can be lowered by manually changing the CAS Latency, tRCD, tRP, cmd timing etc.
To enhance your BCLK, you can adjust this Differential Amplitude. we leave it to AUTO.
There is also CLK SKEW which you can adjust for max BCLK
CPU voltage can be adjusted manually from 0.85v to 1.60v
IMC voltage 1.10 - 1.20v DRAM voltage can be upped to 2.20v (from 1.20v)
CPL PLL from 1.80v to 2.15v PCH voltage 10.5v - 1.40v
