Gigabyte GA-P55-UD6 Mainboard BIOS Screen
shots 1 Bluetooth 30 Aug 2009
BIOS 1
The screen shots are taken with board installed with a Intel Core
i5 750 processor (2.66GHz).
This is the main
bios screen where the sub functions can be accessed form here. The most
important option would be the M.I.T
Under M.I.T, It
shows you different sub menus and a summary of the BIOS, BCLK, Freq, Memory,
temperature, voltages etc.
Once you click on
MIT current status it shows you more details about your configuration.
CPU Multiplier can
be selected in the CPU clock ratio option. When we set the memory to run at
DDR3-2000, the BCLK automatically sets itself to 200MHz and gave us a 13x
multiplier.
Over here you can
set the QPI Clock ratio of 32x or 36x
