ASRock X58 Extreme Intel X58+ICH10R Core i7
Mainboard Review - Introduction
Introduction
Early this year, we reviewed the ASRock X58SupeComputer. It
is the top notch mainboard from ASRock which features 4 X PCIe slots supporting
CrossFireX and Quad-SLI. Although it has the most flexible solutions, the
pricing is generally high for such a well designed board. To bring down the cost of ownership for Intel X58 systems,
ASRock introduced a mid range mainboard based on the Intel X58 chipset. This new
board, ASRock X58 Extreme has some similarities to the X58SuperComputer. The
most important difference is that this board has 3 full length PCIe slots, thus
it cannot support Quad crossfire or Quad SLI. Instead, it added some interesting new features : TPM. TPM or
Trusted Platform Module allows you to secure your working environment with
enhanced data protection via high level encryption and decryption. For DIY users, ASRock added one of our suggestions. That is,
switches for Power On/off, Clear Cmos and Reset. You no longer require a
screw driver to short the circuit to power on/off, clear cmos or reset the
system while you are assembling the system. To help you debug the system, ASRock
also added in Dr.Debug, to show you the BIOS POST diagnostics status of your
system. Other features on this board include Instant Boot to boot up
to Windows in 4secs, a new feature Instant Flash. Instant Flash can be done
within the BIOS Screen and it will search the attached HDD or USB devices for
the BIOS and automatically flash it. The board also supports I.E.S, OC Tuner and
Smart BIOS.
Specifications
