BIOS Screen shots 3 of ASRock M3A785GXH/128M AMD 785G+SB710 Mainboard Review
Bluetooth 13 Aug 2009
BIOS 3
The screen shots are taken with board installed with a AM3 X3 710 processor.
DRAM voltage can be upped to 2.40v CAS Latency, trcd, tras, trp, cmd rate can be set here
Sideport clock speed can be adjusted beyond 1333Mhz to 1700MHz in the pull down menu. To check sideport memory freq, you must AMD oc tool. On board GPU CLK can be selected up to 2GHz
the mGPU voltage can be increase for more stability. The maximum setting is 1.79v HT voltage can be set to 1.30, 1.35v or AUTO
