BIOS Screen shots 4 of ASRock M3A785GXH/128M AMD 785G+SB710 Mainboard Review
Bluetooth 13 Aug 2009
BIOS 4
The screen shots are taken with board installed with a AM3 X3 710 processor.
Sideport voltage can be upped to 1.8v at the max. If you have different settings, e.g. oc settings, ram settings etc, you can save them in 3 different profiles. Just load them accordingly for testing or gaming.
ASrock Instant Flash allows you to flash the BIOS without the need to boot into Windows. Just download the BIOS file, copy it into an external eSATA drive or a FAT32 formatted HDD, it will auto scan for the file and you can choose which version to flash.
