ASRock P45XE-WiFiN Intel P45 chipset mainboard review - BIOS Screen shots
Bluetooth 30 Oct 2008
BIOS 1
The screen shots are taken with board installed with a Intel QX9770.
Main bios screen shot showing the CPU used, memory used on board. BIOS is P1.00 Under Smart BIOS, you can now simply load the Performance or Power Saving defaults. The settings are already optimised for the respective scenarios.
Under Overclock settings. You can change the CPU ratio, Freq, PCIe, FSB Strap, DRAM freq, CPU, Dram,VREF, SB Core voltages etc To overclock a 266 or 333mhz FSB processor, you can fool the system by strapping it as a higher fsb processor thereby giving you more options for the memory divider
CPU Voltage can be upped to 1.60v while DRAM voltage can be upped to 2.72v. SB core voltage can be set Low, Middle, High or Highest
