ASRock P45XE-WiFiN Intel P45 chipset mainboard review - BIOS Screen shots
Bluetooth 30 Oct 2008
BIOS 1
The screen shots are taken with board installed with a Intel QX9770.
SB 1.1v voltage can also be set to low, middle, high or highest GTREF voltage options
The screen shot shows the max voltage settings allowed for CPU voltage, DRAM voltage, NB voltage, VTT voltage and PLL voltage If you use a EPP profile DRAM, you can select auto or choose the profile accordingly. DRAM Freq can also be selected when running the processor in ASYNC to Memory
Two difference profiles are available on our Corsair modules There are 3 save slots for you to save your overclock settings. For example you can set different settings for 3 different scenarios. 1) power saving, 2) gaming , 3) overclocked
