ASRock P45XE-WiFiN Intel P45 chipset mainboard review  - SiSoft Sandra XII
Bluetooth 30 Oct 2008
Benchmarks
In this test, we checked out the difference between the 6 boards, the ASRock P45XE-WiFiN, ASRock P45R2000-WiFi, ECS P45T-A, Gigabyte EP45 Extreme, ASRock P43R1600Twins-WiFi and the ASRock X48TurboTwins-WiFi. The boards are running the ATi Radeon HD 4850 graphics card with an Intel QX9770 processor.
Using CPU-Z, we checked the CPU Clk, the ASRock P45XE-WiFiN runs at 400.3MHz, ASRock P45R2000-WiFi runs at 400.3MHz, ECS P45T-A runs at 400.0Mhz while the Gigabyte EP45 Extreme was clocking at 400.1MHz, ASRock P43RTwins-WiFi is slightly o/c at 400.3MHz  and the ASRock X48TurboTwins-WiFi clocks at 400.0.
ASRock P45XE-WiFiN, ECS P45T-A, Gigabyte GA-EP45 Extreme and ASRock P43R1600Twins-WiFi runs a pair of Kingston DDR2-1100 module at DDR2-1066 @ C5-7-7-24-2T while the ASRock P45R2000-WiFi and X48TurboTwins-WiFi runs a pair of Kingston DDR3-1800 module at DDR3-1600 @ C7-7-24-2T.
For the P45R2000-WiFi, we used the BIOS P1.20 for the test. As P45 doesn't officially support FSB1600, when we set the memory to run at DDR3-1333, it actually runs the memory at DDR3-1200.
We can see that the differences aren't that far apart. Perhaps, the slightly higher clock of 400.3 gave it some advantage in the scores. As we can see, some of the scores are better than the X48 board.
Sandra XII
ASRock P45XE-WiFiN (DDR2-1066) ASRock P45R2000-WiFi (DDR3-1333) ECS P45T-A (DDR2-1066) Gigabyte GA-EP45 Extreme (DDR2-1066) ASRock P43R1600Twins-WiFi (DDR2-1066)
ASRock X48TurboTwins-WiFi (DDR3-1600)
CPU CLK 400.3 400.3 400.0 400.1 400.3 400.0
Memory Bandwidth
7710/7740 7666/7678 7587/7569 7134/7126
7751/7734
8382/8310
Arithmetic Dhrystone ALU
60050 60037 60113 59831
59533
59282
Arithmetic Whetstone iSSE3
47050 47069 46778 45647 46613
46267
Multimedia  Int x8 iSSE3
351750 351798 352864 352954 351904
353115
Multimedia Float x4 iSSE2
193320 192779 193327 193421 192749
193496
