ASRock ConRoe1333-D667
945GC A2 Mainboard Review Intro 1/4
Bluetooth 16 May 2007
of
ASRock ConRoe1333-DVI/H
Introduction
ASRock
has been known for its budget yet innovative boards. Today, we take a look at
their newly released board, the ASRock ConRoe1333-D667. This is the little
brother of the ConRoe1333-DVI/H.
ConRoe1333-D667
supports the LGA 775 for Intel® Dual Core Core™ 2 Extreme / Core™ 2 Duo /
Pentium® D / Pentium® Dual Core / Pentium® 4 / Celeron® / Celeron® D processors.
The board is based on the Intel® 945GC A2 Chipset which is compatible with all
FSB1333/1066/800/533MHz CPUs except Quad Core. The 945GC A2 chipset comes
with Intel® Graphics Media Accelerator 950
which supports Pixel Shader 2.0, DirectX 9.0. It can support up to a Max. shared
memory 224MB.
In terms of
expansion, this board supports Dual Channel
DDRII667/533 x 2 DIMM slots with max. capacity up to 4GB. The board also has 1 x
PCI Express x16 slot for external VGA card. For disk access, there are 4 x
Serial ATAII 3.0 Gb/s connectors. Other than that there is 7.1 CH Windows®
Vista™ Premium Level HD Audio (ALC888 Audio Codec), 10/100 Ethernet LAN.
HD 8CH I/O: 4 ready-to-use USB ports, HD 7.1 channel audio jacks. The board is
Windows® Vista™ Premium 2007 Logo Ready
For overclockers, ASRock throws in the hybrid Booster - Safe Overclocking
Technology
Untied Overclocking : During overclocking, FSB enjoys better margin due to fixed
PCIE/ PCI Buses.
Just like the ConRoe1333-DVI/H
we reviewed a month ago, when running 1333FSB CPUs, the PCIe clk is running at
115MHz (OC).
Specs
General |
CPU |
- LGA 775 for Intel®
Dual Core Core™ 2 Extreme / Core™ 2 Duo / Pentium® D / Pentium®
D
- Compatible with all FSB1333*/1066/800/533MHz CPUs
except Quad Core
- Supports EM64T CPU
Chipset |
- Northbridge: Intel® 945GC A2
- Southbridge: Intel® ICH7 |
Memory |
- 2 x DDRII DIMM slots
- Supports DDRII 667/533
- Max. capacity: 4GB*
BIOS |
- 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- Supports jumperfree
- SMBIOS 2.3.1 Support |
Audio, Video and Networking |
Graphics |
- Intel® Graphics Media Accelerator
950
- Pixel Shader 2.0, DirectX 9.0
- Max. shared memory 224MB |
Audio |
- 7.1 CH Windows® Vista™ Premium
Level HD Audio (ALC888 Audio Codec) |
LAN |
- Realtek PCIE x1 LAN 8101E
- Speed: 10/100 Ethernet
- Supports Wake-On-LAN |
Expansion / Connectivity |
Slots |
- 2 x PCI slots
- 1 x PCI Express x16 slot
- 1 x PCI Express x1 slot
- 1 x HDMR slot |
Connector |
- 4 x Serial ATAII 3.0 Gb/s connectors (No
support for RAID and "Hot Plug" functions)
- 1 x ATA100 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- CPU/Chassis FAN connector
- 20 pin ATX power connector
- 4 pin 12V power connector
- CD in header
- Front panel audio connector
Rear Panel
I/O |
HD 8CH I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x VGA Port
- 1 x RJ-45 LAN Port
Front Speaker / Microphone |
Other Features / Miscellaneous |
Hybrid Booster |
- ASRock U-COP
Support CD |
Version) |
Accessories |
- Quick Installation Guide, Support CD, I/O
Shield
- Floppy/ATA 100 cables
- 1 x COM port bracket |
Hardware
Monitor |
- CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
Form Factor |
- Micro ATX Form Factor: 9.6-in x 9.0-in, 24.4
cm x 22.9 cm |
OS |
- Microsoft® Windows®
2000 / XP / XP 64-bit / Vista™ / Vista™ 64-bit compliant |
Certifications |
- FCC, CE, WHQL |
