Sandra XII Benchmarks of ASRock ALiveDual-eSATA2  ULi M1695 + NF3 250 chipset mainboard
Bluetooth 19 Dec 2007
Benchmarks
We test out the system using Sandra XII benchmarks comparing the 790FX based DFI versus a AMD 770 based board from ECS. We used a X2 5000+ Black edition on both boards.
Sandra XII tests
From the chart, we tested the Arithmetic and multimedia performance of the CPU. All 3 boards involved clocks exactly at 200.00MHz. The three boards all run at DDR2-800 mode at CAS 5, 5-5-18, 2T. We can see very little difference in the results. If we were to compare the price point, the ASRock ALiveDual-eSATA2 does give a better performance/cost ratio as it supports both graphics ports.
Sandra XII DFI LP UT 790FX-M2R (HD 2600XT-PCIe) ECS A770M-A (HD 2600XT-PCIe) ASRock ALiveDual-eSATA2 (HD 2600XT-PCIe)
Memory Bandwidth 7673/7656 7596/7530 7603/7488
Arithmetic - Drystone ALU 18507 17865 17720
Arithmetic - Whetstone iSSE3 15725 15466 15422
Multimedia - Int x8 iSSE3 49148 49024 48726
Multimedia - Float x4 iSSE2 54043 53926 53960
