In the advance setup, you would see the
settings that is particular to the CPU. Options like Vanderpool technolog,
Intel Speedstep can be enabled or disabled. |
Although ram
timings can be adjusted here. It seems that no matter what CAS is supplied,
the CAS Latency is stucked at 5. Probably a BIOS bug. |
You can specify the amount of VGA Share
memory |
You can select DVMT mode, whether it is
FIX, DVMT or COMBO |
