ECS 945GTY-M MoDT (S479) Intel 945GT Review Intro 5/5
Bluetooth 8 Sept 2006
ECS 945G
BIOS Screen shot
For DVMT/FIXED memory, you can select 64 or 128 or Maximum DVMT
The board comes with CPU smart fan control which allows you to tweak the adjustments for a noiseless system
Shutdown temperature - System shuts down if over heat to specified temperature
A screen showing the current CPU temp and system temp.
