ASUS M2N32-SLI Deluxe Wireless Edition Review Intro 5/6 Bluetooth 21 May 2006
from
various
vendors
BIOS II
More voltage adjustments can be set here if the basics are not enough. You
can increase the voltage levels of NB, SB, CPU to NB HT voltage etc.
PEG Link is set to Disabled to prevent it from overclocking the GPU. For
higher 3D performance, you can set to normal, fast or faster depending on
system stability. Choose one that suits your system.
Clock Frequency can be set to DDR2-400,533,667,800. For overclocking, it
would be best to set it to 400 or 533 so that the RAM would not be limiting
factor.
More advance options for tweaking the memory settings.
DRAM Timing controls for tweakers
Output Driver controls e.g. drive strength for MEM, IDE CD
ROM etc.
