CPU <->NB Speed should be lowered to 4x or 3x if you are increasing the CPU
frequency or CLK. Just remember to try and limit your HT speed to be within
1GHz. e.g. if you set your CLK to 300MHz, x3 will give you 900MHz for
Hypertransport which is within 1GHz. |
The BIOS comes with a MUSIC ALARM. You can set the system to play your CD on
each day at the designated time. Will you use this function or is it extra? |
