ASUS M2N32-SLI Deluxe Wireless Edition Review Intro 4/6
Bluetooth 21 May 2006
 Pricing from
various
vendors
BIOS I
In the JumperFree Configuration, you can turn on the AI Timing or set it manually. For comparison benchmarking, we set it to manual to prevent it from auto overclocking. CPU Frequency or CLK can be set up from 200 ~ 425.0MHz.
PCIex16_1 and PCIex16_2 clk can be FIXed at 100 or adjusted up to 200MHz. DDR2 DIMM voltage can be set up to 2.50v
CPU Vcore can run up to 1.5625v for the AM2 X2 4000+
CPU Multiplier can be set up to 10x.  Default multiplier of X2 4000+ is 10x.
