ASUS A8R32-MVP Deluxe
Review Intro 4/5 Bluetooth 17 Mar 2006
from
various
vendors
BIOS I
CPU Multiplier from 4x ~ 25.5x,
CPU Freq can be adjusted up to 400MHz
PCIe Freq can be fix at 100MHz or from to 100 ~ 150MHz
DDR Voltage can be set from 2.60v ~ 3.20v
CPU Overvoltage can be set to +200mV of default. There are also options for
AI clock skew for Channel A and B of the memory. This option might prove
useful to make system ram more stable during overclocking.
North Bridge voltage can be set too. The Core Voltage, HT Bus voltage and
PCIe Voltage can be set to 1.20v~ 1.50v.
South Bridge can be enabled too
for better stability during overclocking.
ASUS's PEG Link overclocks the GPU. You can
set it to Auto, Disabled, Normal, Fast or Faster. In our tests, it is set to
Disabled.
