ASRock ALiveNF4G-DVI AM2 board (NF6100) Review Benchmark 2/8
Bluetooth 8 Aug 2006
Benchmarks
In this test, we measured the CLK used by the boards. Both boards are set to run in SPD mode of the modules which is rated CAS 5, 5-5-15, 2T. Most of ht eother boards are a bit skew off from the standard 200.00MHz.
The ASRock ALiveNF4G-DVI runs on the dot of 200.00MHZ. Sometimes a 0.5~1MHz does affect the results.
With that in mind, we take a look at the memory benchmark scores using Sandra 2007. As the memory controller is built within the CPU, the differences aren't that great.
ASRock ALiveNF4G-DVI scored a 7438/7499 when paired up with the ASUS 7600GT graphics card. With the embedded video, it dropped to 6460/6489. Interestingly, the AM2NF6G-VSTA which uses a newer 6100-405 does better in this test.
