ASrock 775Dual-880Pro Benchmarks 7/9
Benchmarks - Cinebench 2003 3D 9.104 CINEBENCH is the free benchmarking tool for Windows and Mac OS based on the powerful 3D software CINEMA 4D. The tool is set to deliver accurate benchmarks by testing not only a computer's raw processing speed but also all other areas that affect system performance such as OpenGL, multithreading, multiprocessors and Intel's new HT Technology. CINEBENCH includes render tasks that test the performance of
up to 16 multiprocessors on the same computer as well as software-only shading
tests and OpenGL shading tests on huge numbers of animated polygons that will
push any computer to its limits. CPU Benchmark
We can see from the chart above, the CPU benchmark shows that the ASrock isn't slower than the 955X. In fact, in some of the tests, it performs a bit better. Graphics Benchmark
It is apparent that when the board used with AGP will be slower in the OpenGL tests. In PCIe configuration with DDR or DDR2, we can see that the scores are higher if OPenGL SW-L and a bit slower in HW-L. OpenGL Speedup is thus slower than the 955x boards.
