ASrock 775Dual-880Pro Benchmarks 8/9
Bluetooth 24 Aug 200
5
Benchmarks - Clibench 0.717
clibench is a suite of benchmarks, some are self developed other are slightly modified industry standard benchmarks to check up your computer. It shows nicely modifications in a computers setup and differences between different architectures.
  ASrock 775Dual-880Pro (D2P) ASrock 775Dual-880Pro (DP) ASrock 775Dual-880Pro (D2A) ASrock 775Dual-880Pro (DA) EPoX 5NVA+SLI Gigabyte GA-8I955X Royal Foxconn 955X7AA-8EKRS2
Dhrystone 2.1 8211 8213 8285 8287 4115 8253 8239
Whetstone 1926 1927 1925 1922 966 1927 1923
Eight queens problem 9782 9813 9852 9853 4894 9772
9904
Matrix operations 385153 365025 390320 390324 194081 391661 387320
Number crunch 311052 311052 303608 303617 156042 310641 312084
Floating point 22021 22009 22205 22210 11032 21657 21583
Memory throughput 1879796 1799803 1767050 1767060 1275453 1986618 1928116
Comparing the PCIe/DDR2-533 combination with the 955X platforms, we can see that the ASrock 755Dual-880Pro performs pretty well. It it a bit slower but the difference isn't that much.
See Conclusion >>>
