ASrock 775Dual-880Pro Benchmarks 3/9
Bluetooth 24 Aug 200
5
Benchmarks PCmark2004
PCmark2004 tests a number of important items in today's computing world. File Compression, Encryption, Decryption, Audio Conversion, Web Page Rendering, WMV Video Compression, DivX Video Compression, Physics Calculation and 3D, Graphics Memory etc.
From the benchmarks below, it is very apparent that PCmark2004 is using dual core to process multiple instructions at the same time. As the NF4 SLI Intel edition chipset does not support 820D, the results is not comparable to the PT880Pro and two 955X boards. From the chart, we can see that the ASrock 775Dual-880Pro does pretty well against the Foxconn and Gigabyte 955X boards.
If you notice, the difference between the 4 scenarios do not differ too much as PCmark is not very dependent on graphics.
System Test Suite
ASrock 775Dual-880Pro (D2P) EPoX 5NVA+SLI Gigabyte GA-8I955X Royal Foxconn 955X7AA-8EKRS2
Multithreaded Test 1 / File Compression
5.341 3.201 MB/s 6.2 MB/s 5.873MB/s
Multithreaded Test 1 / File Encryption
73.084 39.805 MB/s 80.69 MB/s 79.864 MB/s
Multithreaded Test 2 / File Decompression
55.584 27.856 MB/s 55.99 MB/s 56.170 MB/s
Multithreaded Test 2 / Image Processing
23.755 11.839 MPixels/s 23.9 MPixels/s 23.575 MPixels/s
Multithreaded Test 3 / Virus Scanning
4610.209 2392.526 MB/s 4327.4 MB/s 4324.505 MB/s
Multithreaded Test 3 / Grammar Check
3.995 2.136 KB/s 4.1 KB/s 4.008 KB/s
File Decryption
79.918 79.8 MB/s 80.28 MB/s 80.451 MB/s
Audio Conversion
2182.378 2180.677 KB/s 2193.48 KB/s 2200.040 KB/s
Web Page Rendering
5.644 5.4 Pages/s 5.65 Pages/s 5.582 Pages/s
65.893 42.931 FPS 68.3 FPS 66.556 FPS
77.222 58.275 FPS 76.82 FPS 77.049 FPS
158.488 157.543 FPS 158.42 FPS 157.879 FPS
Graphics Memory - 64 Lines
1576.813 2085.693 FPS 2039.48 FPS 1991.005 FPS
PCmark05 Results
In PCmark05, we can see that running the board with DDR2 + PCIe gives is a better boost compared to the board with AGP 8x card. The scores using DDR2-533 versus DDR400 both at their most aggressive timings didn't differ a lot.
System Test Suite
HDD - XP Startup 8.26 MB/s
Physics and 3D 117.65 FPS
Transparent Windows 652.08 Windows/s
3D - Pixel Shader 91.43 FPS
Web Page Rendering 2.72 Pages/s
File Decryption 61.58 MB/s
Graphics Memory - 64 Lines 854.3 FPS
HDD - General Usage 5.63 MB/s
Multithreaded Test 1 / Audio Compression 1581.37 KB/s
Multithreaded Test 1 / Video Encoding 273.33 KB/s
Multithreaded Test 2 / Text Edit 109.3 Pages/s
Multithreaded Test 2 / Image Decompression 22.32 MPixels/s
Multithreaded Test 3 / File Compression 3.49 MB/s
Multithreaded Test 3 / File Encryption 31.26 MB/s
Multithreaded Test 3 / HDD - Virus Scan 30.53 MB/s
Multithreaded Test 3 / Memory Latency - Random 16 MB 8.28 MAccesses/s
HDD Test Suite
HDD - XP Startup 8.18 MB/s
HDD - Application Loading 6.85 MB/s
HDD - General Usage 5.64 MB/s
HDD - Virus Scan 77.5 MB/s
HDD - File Write 43.65 MB/s
The results of the HDD tests are quite good and it is on par with the NF4 SLI (K8) platforms.
