ASrock 775Dual-880Pro Benchmarks 4/9
Bluetooth 24 Aug 200
5
Benchmarks - 3Dmark2003/3DMark2005
With Forceware 71.84 (64 bits) installed for Windows Professional XP 64 bits, we ran the 3Dmark2003 and 3DMark2005 with the Pixelview 6600GT card. For AGP 8x, we used the Gigabyte 9800XT with Catalyst 5.8 (64 bits)The follow results were registered.
In 3Dmark2003, we can see that the scores of ASrock 775Dual-880P is not very far off from the 955X boards. Comparing the board with PCIe/DDR2 combination with the fastest 955X board, the difference is less than 0.7%.
In 3Dmark2005, the difference between the two is more apparent. ASrock 775Dual-880Pro scored 3058 whereas the fastest 955X scored 3380. The difference is more apparent here because the PCIe is running at PCIex4.
