Samsung LS15M13C 15" LCD TV (1)
Samsung LS15M13C 15" LCD TV Recently, Samsung releases two new LCD TV with Teletext to the market. LS15M13C is a 15" version of this TV and it comes with a retractable stand allowing you to tilt the screen angle up to 13 degrees to the vertical. Finished in silver, it compliments modern homes. This TV set also support the VESA mounting standard which allows you to hook the LCD TV onto a mounting device. The LS15M13C supports NICAM Stereo/Dual sound broadcasts. Colour standards supported are PAL/SECAM, NTSC 3.58 and 4.43 Below are the specifications :
![]() Front view of LCD TV
Back panel of LCD TV. S-Video in, AV in (Video, Audio L, Audio R), Component Input Y, Pb, Pr(3 ports) + audio ports. Next >>> |
