EPoX 4PDA5+ Intel 865PE/ICH4
P4 Mainboard Review (3)
Benchmarking Before we benchmark, we document the FSB the board is running at. The boards defaults to different FSB. This can result in skewed results. The FSB of the boards tested are indicated in the chart below : The EPoX 4PDA5+ based on 865PE challenges the other boards and scored a high of 4911/4932. This result is apparent that EPoX got the PAT hacked. Although both 865PE boards are running close to 200MHz. The DFI board is running at a slightly higher 200.5MHz resulting in a higher score.
