CPU Vcore is
selectable from 0.80v to 1.55v. This forms the base voltage. CPU Vid
allows you to offset the base voltage with a percentage |
CPU Vid
allows you to offset the base voltage with a percentage as shown above. |
Chipset
Voltage can be set up to 1.90V. We ran our o/c test with a chipset voltage
of 1.80v |
AGP Voltage can be set up to
1.80v |
DRAM Voltage is seletable of up to 3.10v |
