Chaintech VNF3-250 NF3-250 Mainboard Preview (3)
Gortok 8 May 2004
BIOS (II)
All of these are pretty much standard fare. Most of the settings we'll be adjusting will be on the Frequency/Voltage Control page. Here, once Voltage Fine Tune is Enabled, CPU voltage can be set up to 1.7v
The AGP can be set up to 2.2V (I still have no idea why anyone would push the AGP volts that high)
Voltage to the DDR can be set as high as 2.9v. This should help keep the RAM more stable at higher speeds.
Chipset voltage can be adjusted, as well.
In the DRAM configuration page, RAM timings can be adjusted...
