ASRock K8S8X (SIS 755) Multiplier enabled BIOS (2)
Bluetooth 29 June 2004
Today, we received a new beta BIOS from ASrock. This BETA BIOS is an experimental BIOS and it includes two major inclusions.
The default screen showing the CPU used and the RAM on board
Under BIOS Setup Utility, you can adjust the Frequency, Enabled or Disable Cool 'n' Quiet. You can also set the multiplier and processor voltage on this screen.
FSB range is from 140MHz ~ 300MHz.
The Maxmemclk can be selected from the drop down menu. Ram Timings can also be adjusted.
Discuss in ASrock sector
