ASrock K8S8X (SiS755) Gallery/Preview
(2) Bluetooth 25 Feb 2004
The Mainboard
Finished in blue, it looks much better compared
to the dirty green that the previous series used. On the mainboard we can see
that the North Bridge uses a big heatsink. Did you also noticed that the design
looks closer to the ASUS boards. Even the printing on the PCB uses the same font
5 PCI slots,
1 AGP 8x Slot. On the mainboard is the audio codec CMI 9739A
2 DIMM slots
supporting up to 2GB of DDR400. Socket 754. The Power connector is located
separately from the +12 v connector.
Floppy
Connector, BIOS chip, front panel connector. SATA Ports and South
Bridge SiS 964
The +12v connector. IDE connectors.
Looks like a 2 phase power is in use.
The back
panel with PS/2 Keyboard,Mouse connector. 1 COM port. 1 Parallel port. 6
USB, 1 LAN and 6 channel audio ports.
The ClkGen
responsible for the large range of FSB to 300MHz
