ASrock K8S8X (SiS755) Gallery/Preview (3)
Bluetooth 25 Feb 2004
The BIOS
CPU Host frequency can be set to AUTO or Manual. When set to Manual, you can adjust it from 140 ~ 300MHz FSB at 1MHz stepping. AMD Cool N Quiet is enabled by default. The Memory Configuration has lots of options. The memory clock can be set to operate at 100,133,166,200, that is to say you can run memory at 166, that would be 200:166 Async mode.
Most users would be interested in these settings like the CAS Latency, TRCD, TRAS and TRP. In our tests, we set them to run at CAS 2, 5-2-2. We left the others at default.
AGP Aperture size is set to 128MB, AGP Data rate at 8x, Fast Write was off by default, we enabled it. In the Hypertransport configuration, we set HT Width to 16 bits, HT speed to 800MHz, There are two other options which we left at default.
