ASrock K7Upgrade-880 VIA KT880 Socket A Review 4/7
Bluetooth 17 Sep 2004
Benchmarks - 3Dmark2001SE/3DMark2003
Using the Gigabyte Radeon 9700Pro graphics card, we ran 3DMark2001SE and 2003. It scored 15667 which is a bit on the low side. I think this is due to the ram timings used. If the memory voltage can be adjusted higher, I suppose running it at cas 2,6-2-2 shouldn't be a problem.
In 3Dmark2003, the board performs a bit better than the 7S748-L but it is surprisingly slower than the VT600 chipset. Looks like the BIOS might not be tuned for performance as yet.
