ASrock K7Upgrade-880 VIA KT880 Socket A Review 5/7
Bluetooth 17 Sep 2004
Benchmarks - Q3
The ASrock K7Upgrade-880  scores 307.2 fps in this test. Although the KT880 chipset is a dual channel chipset, the performance is a bit weak due to the ram timings used. Some of the NF2 boards are running higher than 200MHz and  that has some impact on the overall performance.
