SiS 748 Ref Mainboard Review (1)
Bluetooth
2 June 2003
After a long wait, the SiS 748 Reference board arrived in our labs last week. SiS 748 is the latest K7 chipset from SiS which supports the latest 200Mhz FSB processors or 400Mhz processors e.g. Barton AXP3200+. Featuring the hyperstreaming technolgy, it allows this single channel DDR400 solution as fast as current DDR400 K7 solutions available on the market today.
So what is Hyperstreaming ? Basically hyperstreaming technology is optimised for
  • “Low Latency” with Single stream
  • “Pipelining” and “Concurrent Execution” with Multiple streams
  • “Prioritized Channel” with Specific stream
  • “Smart flow control” and “Intelligent arbitration” with Smart stream
This new technology avoids many of the out-of-sync audio, jittery images, low frame rates and possible packet transfer errors. With this new technology, it makes single channel as good as a dual channel design.  You can read more about the technology at this SiS website.
The SiS 748/963L incorporates 1 MuTIOL 1GB/s bandwidth for all the devices that reduce potential bottlenecks. This greatly enhances system responsiveness.
Will the SiS 748 be another success making it the most affordable and cost effective K7 solution like the SiS 735 ? We shall take a look. First of all, let's take a look at the board and BIOS screen shots.
Features Benefits
CPU supported AMD Athlon XP FSB 400 MHz.
DDR400 support Support Maximum Memory Bandwidth 3.2G/B.
MuTIOL 1G® technology Proprietary Interconnect between SiS748 and SiS963L.SiS MuTIOL® 1G deliver 1GB/s bandwidth.
8X AGP upgrade flexibility Make system performance upgrade and user's facilitation. Support Maximum AGP interface bandwidth 2.1GB/s. Backwards compatible with AGP 4X.
ATA133 enhancement Fastest storage support. Increasing data/file transfer rate.
AC97 Controller Hollywood 3D stereo enriches audio surrounding with up to six channels.
Integrated Communication Controller for LAN or HPNA use MII interface used for 10/100Mbps LAN or 1/10Mbps HomePNA function. Reaching cost-effective solution and design elasticity.
Integrated USB2.0 Controllers One controller for six ports, achieving real legacy free systems.
