Top Right Corner of the mainboard. From here we can see 5
PCI slots and 1 AGP slot. The on board audio codec used is Cmedia 9739Al. WINBOND
W83627THF-A IO Controller chip is seen on the corner of the board. |
A 3 phase voltage regulator design is
implemented with +12v aux power connector for stable 12v line. At the back
panel, there are 4 USB ports, 6 channel audio ports and 2 LAN ports (suppoted
by Realtek and nVIDIA) |
SATA RAID supported by SiliconImage
Sil3112chip. 2 channels of ATA133. 1394 supported (white connectors) by
agero fw323-60 chipset |
3 DIMM slots supporting up to 4GB of
DDR266/DDR333/DDR400 using 184pin unbuffered |
Another view of the bottom left corner of
the mainboard showing the DEBUG LED, BIOS, chipsets, south bridge. |
Close up view of the power connectors and
voltage regulator |
nForce2 SPP, the latest C1 stepping. |
nForce2 MCP, Epox 8RDA+ uses MCP-T |
Attansic ATXP3
Jumper Free Over Clock Controller
FID, VID In/Out Put Pins
Up To 12GPIO
Auto-recover
Provide CPU Changing Detect Pin |
Back Panel : PS/2 Mouse, keyboard, 4 USB 2.0, 2 LAN, audio ports. |
