ECS L7S7A2 SiS 746 Mainboard
Review (3)
Benchmarking Memory Benchmarks (fsb:166, AXP2700+) SiSoft Sandra 2002 The infamous SiSoft Sandra 2002 is used to test out the memory benchmarks, CPU Arithmetic and Multimedia benchmarks. All the systems are tweak to it's maximum possible settings of CAS 2, 2-2-5. All boards running in SYNC DDR333 (166/166) otherwise specified. The FSB of the various boards are : ECS L7S7A2 : 166.65Mhz In SiSoft Memory benchmarks, we can see from here that the ECS L7S7A2 performs better when it runs in Async DDR400 mode. It lost to SiS 746FX board by a bit considering that the fsb is slightly lower and the BIOS is the first official bios which has not been tuned for performance. In the CPU Multimedia tests, the ECS L7S7A2 seems to perform better if FPU than ALU. We have mixed results here. The FPU performance seems better on the L7S7A2. Again we see that the FPU performance in this test is better on ECS L7S7A2. |
