Review : Mainboard Layout of ASROCK AOD790GX/128M  AMD 790GX+SB750 mainboard
Bluetooth 15 Sep 2008
Gallery
The board comes with a 5 phase voltage design. It has 3 PCI and 2 PCIe x16 (either 1 x PCIe x16 or 2 x PCIe x 8 for CrossFire) and 1 PCIe x1 on board. Realtek and GbE 8 ch audio codec are sighted on board.  Both north, south bridges are cooled passively with copper heatsink. Between the two PCIe x16 slots is a peddle card to switch the slots to operate in dual by 8 or single by 16.
The board supports four 240-pin unbuffered non-ECC DDR II SDRAM DIMM sockets with up to 8GB of memory can be installed on board. For AM2 processors, DDR2-533/667/800 is supported. For Phenom AM2+, memory supported is DDR2-667/800/1066. It also support Asynchronous clocking mode between FSB and DIMM.
The new SB750 supports 12 USB connectors compliant with USB2.0 from embedded USB controller (4 connectors at rear panel). The SB750 supports S-ATA RAID with 6 S-ATA II ports with up to 300MB/s from chipset with RAID 0,1,0+1,5 support. The VIA controller supports 1394.
At the rear panel are PS/2 keyboard connector. There is a D-SUB, DVI. There are 6 USB ports,1 esata port, 1 1394, 1 GbE and8 ch HDA audio ports. HDMI out is achieved by attaching the D-SUB->HDMI converter provided in the package.
