ASROCK AOD790GX/128M  AMD 790GX+SB750 mainboard  - Benchmarks SiSoft Sandra XII
Bluetooth 16 Sep 2008
Benchmarks
The board is tested with a AMD Phenom 9550 running a pair of DDR2-1066 modules. The test is done using the on board UMA at default. On board UMA memory runs at 533Mhz. e.g. 700/533. Sideport is disabled.
Windows Experience Index = 3.5
Here is a breakdown of the scores of 3 AMD 790GX boards. The ASRock AOD790GX/128M comes with a 128M Sideport using DDR2-800, the BIOSTAR comes with 64M of DDR2-800, the Gigabyte GA-MA790GP-DS4H comes with DDR3 memory.
Sandra XII ASRock AOD790GX
/128M
Biostar TA790GX A2+ Gigabyte GA-MA790GP-DS4H
CPU CLK 200MHz 200MHz 200MHz
Memory Bandwidth 5437/5454 5161/5173 5442/5458
Arithmetic - Dhrystone ALU 32541 32797 32906
Arithmetic - Whetstone iSSE3 28421 28392 28328
Multimedia - Int x8 iSSE3 83827 83805 113250
Multimedia - Float x4 iSSE2 110471 110144 109956
Drive Index 47MB/s 47MB/s 48MB/s
Random Access 8ms 9ms 8 ms
