Gigabyte GA-965P-DQ6 (i965P) Core 2 Duo Mainboard Review Benchmarks 9/11
Benchmarks - RealStorm
This tool does realtime raytracing, a very
computational intensive application that does software rendering. Thus, it
requires high speed processors to do it. The author said "Of course
3D-Accelerators are getting faster too and evolve feature-wise, but beyond a
certain level of detail, a polygon has to be smaller than a pixel on the screen.
In this case, there is absolutely no reason to use polygon routines. So we
decided to use platonic solids combined with boolean algebra and raytracing. From the chart below, it can be clearly seen that the benchmarks are very close to one another. In fact, in this cpu intensive application test, we noticed that a difference in the cpu clk does make a lot of difference to the scores. So, when reading the benchmarks it is always goood to bear in mind the default fsb the board is running atl
