ECS
PN2-SLI2+ Review Benchmarks -
Sandra 2007
Benchmarks Sandra 07 The boards are first measured to ensure accuracy of CLK. In CPUZ test, we see that the CLK of the Gigabyte GA-965P-DQ6 is at 266.7 while the ASRock 4CoreDual-VSTA is at 266.1MHz. In the tests to follow, the Gigabyte board is ran with 2GB of Corsair DDR2 running at CAS 5, 5-5-18 DDR2-800 mode while the ASRock 4CoreDual-VSTA will run in DDR mode with 1GB of Corsair memory at CAS 2, 2-2-5, 1T cmd and in DDR2 mode, it is run with the same pair of DDR2 modules (2GB) running at CAS 3, 3-3-8, 1T cmd DDR2-533. The ECS PN2 SLI2+ runs at 266.7 which is just exactly at the same clk speed as the Gigabyte GA-965P-DQ6.
From the chart below, we can see that ECS PN2 SLI2+ seems to do better in terms of memory controller giving us a better score compared to the Gigabyte board based on i965P chipset. Will that translate to better scores in other tests? Lets press on.
