Gigabyte K8S760M (SiS760)
Review
(5)
Benchmarking We checked out Q3 running Demo001 at 1024x768x32 Hi-Quality. Tyan Radeon 9700Pro is used and is running in 8X mode with Catalyst 3.2 (7.84) drivers for all boards tested. The score is 379.9fps which is one of the fastest K8 boards around. In fact a difference of 0.5~1fps doesn't make much difference. From the chart, other than the SiS Ref and 755-A2, the other few boards are running slightly higher FSB which resulted in a higher score in Quake 3.
In Comanche 4 benchmarks, 67.29 is recorded. The results are faster than the other SiS 755 boards. On the top of the charts are some VIA and ALi based boards which is slightly faster but their FSB is not 200.00 exact. It even outperformed the ASrock SIS 755.
