DiVX Encoding tests benchmark
of
ECS H55H-CM Intel H55 ClarkDale Mainboard
Benchmarks - DIVX 7 encoder In this test, a full HD clip is put to the compression test to Divx Plus HD and Divx Mobile Format. In the chart below, the shorter the time to completion equates better performance. From the numbers shown below, we can see that the faster platform is the Intel H55. The AMD 785G is almost on par but just split seconds slower than the rest. The ECS H55H-CM is just split seconds behind the ASUS which runs at 133.8MHz but ASRock leading the way due to it's higher default clock at 138MHz.
