DiVX Encoding tests benchmark
of
Biostar TH55XE Intel H55 ClarkDale Mainboard
Benchmarks - DIVX 7 encoder In this test, a full HD clip (the Bourne ultimatum) is put to the compression test to Divx Plus HD and Divx Mobile Format. In the chart below, the shorter the time to completion equates better performance. From the numbers shown below, we can see that the faster platform is the Intel H55. Among the 3 Intel H55 boards, the ASRock H55M Pro gives the fastest encoding result. The first runner up is the Biostar TH55XE. The AMD 785G is almost on par but just split seconds slower than the rest.
