Samsung Corby Pro  B5310 Review [HD]
Bluetooth 18 Nov 2009
Samsung Corby Pro
The Corby Pro is another phone under the Corby series. Doing away with the tiny screen, this phone comes with a TouchWiz and a slide out QWERTY keyboard.
We can see the bright colour scheme used on the Corby Pro. It blends in a red keypad with white cover plate at the back. From the looks of it, this phone looks rather slim on the side.
This phone can operate through touch screen with it's 2.8" TFT display. It also supports TouchWiz and One touch zoom just like Samsung Jet. With it's high speed connectivity of HSDPA 7,2mbps, this phone is definitely higher in specifications compared to the Corby TXT. It has a 3 megapixel CMOS Camera, FM radio (RDS), WIFI, BT, USB 2.0, etc.
For those who prefer to use the keyboard, the QWERTY provides easy email and SMSing. With it, updating MySpace or Facebook is easier as these applications are already pre built into the phone. The phone also support push mail services and threaded SMS.
We did a test on the phone and found the TouchWiz is quite intuitive. Messaging via the keyboard is also simpler as I prefer text input than writing on a screen.
If you do not need a Windows Mobile 6.5 Omnia Pro B7320, this phone could be a good consideration. It runs on proprietary Samsung OS.
Samsung CorbyPRO (B5310) Specifications
Network
HSDPA 7.2Mbps, 900/2100
EDGE/GPRS, Quad Band (850/900/1800/1900MHz)
Display
2.8” TFT 16M QVGA Full touch screen
Camera
3 Megapixel FF, CMOS
Video
H.263, MPEG4, WMV, WAV, DivX,
Audio
FM Radio with RDS
Poly 64, SP-Midi, i-melody, MP3, AAC, AAC+, WMA
Value-added
Features
Fashion Jackets (Changeable battery cover)
Cartoon UI, One Finger Zoom, Smart Unlock
Connectivity
WiFi, BT 2.1. USB 2.0, microUSB, 3.5mm earjack
Memory
100MB + microSD (up to 16GB)
Size
105 x 56.8 x 15.68 mm
Weight
135g
Battery
960mAh
